05ram4x4
- Aug 28, 2012
- 597
- 34
- 2002 Ram 2500 4x4 Quad cab
- 5.9 Magnum
One is a shake or shutter I get while driving. It's only when i am part throttle. If I am cruising at a consistent speed it's fine. If I let off the pedal the slightest bit the whole truck shakes like crazy. It also does it when I first start to move and release the brake pedal just a little bit. I want to say it's because of the rough idle the engine has.
Which brings me to the second problem. Why is my engine running rough? I just did the plenum gasket. But it was happening before that too. I don't believe there are any misfires (I did the pull each plug and see if it changed method. Also with injectors). I've read online that maybe there could be a head gasket leak? Or a valve leak? Any idea? Or how to test?
Final problem. This damn oil light and gauge are annoying the hell out of me. I replaced the sending unit a while ago. Nothing has changed. I believe there is a short in the cluster, but where do I look? I took the cluster apart and cleaned it. Everything looked fine. I say it's a short because when the tach needle gets to about 1000 rpms...the oil light flickers. As the needle drops it gets more consistent until it's finally just on. Sometimes when that happens the gauge drops to nothing as if it lost all signal. I am at a loss for this one. I'm thinking about taking a tach from the junk yard and swapping it out. Maybe my tach is bad internally?
ANY help is greatly appreciated!
