Hey folks, I recently swapped out the 5.9 in our 1995 Ram 4x4 for one out of a 1998. After a fiasco with flex plates and torque converters not making nice that since been resolved, now it wants to detonate above 3500 rpm under WOT. I swapped the plugs for some Autolite 3923's gapped at .040 but that didn't help. I have yet to run some 93 through it to see if that helps as the tank is full of 87. I just recently discovered it was doing this as I hadn't really romped on it since the swap. And I'm used to pulling some timing via a twist of the distributor but i dont thin it works that way on these trucks. Only other issue is surging while cold, but after it warms up it runs great. I'm wondering about the lack of an EGR on the new motor. I used the factory 1995 computer and harness, but the 98 motor didn't have an EGR. I had to reuse many of the sensors off the 95 motor because the ones on the 98 were different. Any ideas to combat the pre ignition? Thanks, you guys are awesome.
