bassslayer25
- Feb 7, 2014
- 2,052
- 774
- East, Kansas
- 2000
- 5.9 360 V8
Gonna try and make this as simple as possible.
Couple days ago truck stalled on me pulling into gas station. Started right back up and went home. A day later, while in town, truck stalled out again. Same thing, all lights and stereo worked but I got a "no bus" code along with CEL.
Get it towed home and start trouble shooting. I replaced the coolant temp sensor this past saturday and it started up afterwards. Took it for a test drive then it stalled maybe 5 mins later and I got the "no bus" code again. My brother towed me home and it hasnt started every since.
Since then I have went to a salvage yard and got a new PCM and that didnt solve the issue either. My dad has an 01 Ram with the same engine so I took his PCM out and plugged it into mine and nothing changed again. So that leaves me to believe that its not the PCM? Am I correct on that?
*I guess I should mention that any time I turn the key into the on position the ASD relay starts clicking rapidly.
So I just got done replacing the Crankshaft position sensor and still nothing has changed. Thinking about replacing the ignition coil now.
However, before I do that does anyone have any input on what the hell this could be? This has been, by far, the most frustrating problem the truck has given me. Thanks in advance.
