Engine & Performance starting issue
This is a discussion on starting issue within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category! Register to remove these ads. It's free!
Ok, I know theres a TON of other "hard starting" threads...I've looked through ...
02-06-2012, 01:08 PM
#1 (permalink)
Ram Year: 1997
Engine: Magnum 5.9
starting issue
Ok, I know theres a TON of other "hard starting" threads...I've looked through them all, none seem like mine...I turn the truck over for 2 second..cranks....let off, crank again, fires right up...my battery was toast, so I upgraded to an 800 cca battery...still does it...warm it just starts right away...Ive owned the truck for about 1 1/2 and it has always done this...any ideas? Thanks!!
BTW tuned....no leaks at the plenum, so could it be the IAC?
02-06-2012, 03:59 PM
#2 (permalink)
Ram Year: 1997
Engine: Magnum 5.9
ok, so far problem solved...maybe this will help others in the future...use a t25 remove both screws holding IAC (on the back side of the throttle body) in place...a can of carb cleaner (and a flathead screwdrive may be needed for hard built up carbon) towel, and qtips...clean thoroughly until you can see the brass shaft...push inner shaft down a bit (not alot!!! maybe 1/8 of an inch just to make sure the spring is still good) now thoroughly clean out the port it goes into with qtips ( it can take some time for this part)...reassemble, should be good to go! after i did this, reconnected the batt...key in...1 1/2 cranks fired right up..
02-07-2012, 06:23 PM
#3 (permalink)
Ram Year: 1999
Engine: 5.2L 318ci Magnum
Ive had this same problem on my 99 5.2 too! Its really got me stumped. But today in school i tested the fuel pressure on the rail, and when its at key on, engine off, it jumps to 50-51, then slowly bleeds down to 0. I havent tried cleanin my IAC yet though either, I was actually thinkin about replacin the fuel pressure regulator. But ill try cleanin the IAC first and see what happens after that. Thanks for the thread!
__________________
1999 Ram 1500 4x4 318ci, 5spd, regular cab, short bed.
Mods: Flowmaster muffler, hollowed-out cat, 5" Tuff Country suspension lift, 35" tires, LED tailgate bar, Bully truck steps, pocket fender flares, cab lights, black grille shell with red inserts, bug shield, CAI, ported and polished throttle body, and more to come!
02-07-2012, 08:13 PM
#4 (permalink)
Ram Year: 2002
Engine: magnum 5.9
ok my 2002 5.9 had a similar problem. crank key (couple seconds) let off crank again it starts. It ended up being a fuel regulator.
02-08-2012, 08:17 PM
#5 (permalink)
Ram Year: 1999
yeah, i think im gonna end up havin to replace that. But one day soon when its not too cold out, i gonna take off my IAC and clean that bc it wouldnt hurt to clean it anyway..and my truck sometimes gets a jumpy idle at lights and stuff too. But ill be in the market for a regulator in the near future.
__________________
02-09-2012, 08:54 AM
#6 (permalink)
Ram Year: 1996
Engine: 318 or 5.2 which ever you want
Hmm be careful what "carb" cleaner you use as some aren't very friendly with sensor's. Use a sensor or fuel injector cleaner.
02-19-2012, 11:19 PM
#7 (permalink)
Ram Year: 1999
well, i cleaned my iac (which was pretty grimy lookin btw) still have the starting problem. Im gonna shop around on the net and locally and see whos got the best price on a regulator, and install it. Im really thinkin thats gonna fix the problem though bein that i have a new fuel pump and clean iac...
__________________
02-21-2012, 11:18 PM
#8 (permalink)
Ram Year: 2000
Engine: 5.9 magnum
if you have a new fuel pump you also have a new regulator they are sold as one unit
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
