Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Sponsored Ads
Register to remove these ads.
starting issue
This is a discussion on starting issue within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! Ok, I know theres a TON of other "hard starting" threads...I've looked through ...
Reply
Old 02-06-2012, 01:08 PM   #1 (permalink)
Ram Year: 1997
Engine: Magnum 5.9
Default starting issue
Ok, I know theres a TON of other "hard starting" threads...I've looked through them all, none seem like mine...I turn the truck over for 2 second..cranks....let off, crank again, fires right up...my battery was toast, so I upgraded to an 800 cca battery...still does it...warm it just starts right away...Ive owned the truck for about 1 1/2 and it has always done this...any ideas? Thanks!!
BTW tuned....no leaks at the plenum, so could it be the IAC?
RobS is offline   Reply With Quote
Old 02-06-2012, 03:59 PM   #2 (permalink)
Ram Year: 1997
Engine: Magnum 5.9
Default
ok, so far problem solved...maybe this will help others in the future...use a t25 remove both screws holding IAC (on the back side of the throttle body) in place...a can of carb cleaner (and a flathead screwdrive may be needed for hard built up carbon) towel, and qtips...clean thoroughly until you can see the brass shaft...push inner shaft down a bit (not alot!!! maybe 1/8 of an inch just to make sure the spring is still good) now thoroughly clean out the port it goes into with qtips ( it can take some time for this part)...reassemble, should be good to go! after i did this, reconnected the batt...key in...1 1/2 cranks fired right up..
Old 02-07-2012, 06:23 PM   #3 (permalink)
ktm1217's Avatar
Ram Year: 1999
Engine: 5.2L 318ci Magnum
Default
Ive had this same problem on my 99 5.2 too! Its really got me stumped. But today in school i tested the fuel pressure on the rail, and when its at key on, engine off, it jumps to 50-51, then slowly bleeds down to 0. I havent tried cleanin my IAC yet though either, I was actually thinkin about replacin the fuel pressure regulator. But ill try cleanin the IAC first and see what happens after that. Thanks for the thread!
__________________
1999 Ram 1500 4x4 318ci, 5spd, regular cab, short bed.
Mods: Flowmaster muffler, hollowed-out cat, 5" Tuff Country suspension lift, 35" tires, LED tailgate bar, Bully truck steps, pocket fender flares, cab lights, black grille shell with red inserts, bug shield, CAI, ported and polished throttle body, and more to come!
ktm1217 is offline   Reply With Quote
Old 02-07-2012, 08:13 PM   #4 (permalink)
suzukiquadrider's Avatar
Ram Year: 2002
Engine: magnum 5.9
Default
ok my 2002 5.9 had a similar problem. crank key (couple seconds) let off crank again it starts. It ended up being a fuel regulator.
suzukiquadrider is online now   Reply With Quote
Old 02-08-2012, 08:17 PM   #5 (permalink)
ktm1217's Avatar
Ram Year: 1999
Default
yeah, i think im gonna end up havin to replace that. But one day soon when its not too cold out, i gonna take off my IAC and clean that bc it wouldnt hurt to clean it anyway..and my truck sometimes gets a jumpy idle at lights and stuff too. But ill be in the market for a regulator in the near future.
__________________
Old 02-09-2012, 08:54 AM   #6 (permalink)
Hotroder383's Avatar
Ram Year: 1996
Engine: 318 or 5.2 which ever you want
Default
Hmm be careful what "carb" cleaner you use as some aren't very friendly with sensor's. Use a sensor or fuel injector cleaner.
Hotroder383 is offline   Reply With Quote
Old 02-19-2012, 11:19 PM   #7 (permalink)
ktm1217's Avatar
Ram Year: 1999
Default
well, i cleaned my iac (which was pretty grimy lookin btw) still have the starting problem. Im gonna shop around on the net and locally and see whos got the best price on a regulator, and install it. Im really thinkin thats gonna fix the problem though bein that i have a new fuel pump and clean iac...
__________________
Old 02-21-2012, 11:18 PM   #8 (permalink)
RAMMIT's Avatar
Ram Year: 2000
Engine: 5.9 magnum
Default
if you have a new fuel pump you also have a new regulator they are sold as one unit
RAMMIT is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Starting RobS Tech Info 5 02-21-2012 10:23 AM
Starting without Fob? Stagman General Discussions 10 01-23-2012 09:53 PM
starting to think about gears.. AJMAG Engine & Performance 7 07-15-2011 12:06 PM
Starting problem txbass06 Engine & Performance 6 07-07-2011 02:35 PM
5.2 Hard Starting ktm1217 Engine & Performance 24 06-09-2011 04:42 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
