Blue Truck
- May 31, 2015
- 72
- 60
- Skagit County WA
- 2003
- No Spark Plugs
Searched for hours on this and now can't find my notes, but I suspect I have two issues going on right now. Can anyone offer confirmation or other ideas? No codes are being thrown, so I can only go based on observed symptoms.
1. Once in a while (maybe every six months?) the truck will start (restart after being driven and fully warm) and immediately die. It might take several tries to start again at that point and will idle roughly for a short period. If I give it a little gas, that helps. Feels like starting a carbed vehicle with a bad choke while cold.
1a. I don't seem to have a high idle, even when starting in cold weather. Engine fires right away and typically runs smoothly, but it's at normal idle level as if it was already warmed up.
I suspect ECM. Any way to further diagnose? Could it possibly be related to a bad TPS? (see below)
2. Torque converter locks up nomally, but it won't unlock unlock until I slow down to about 35 to 37 MPH, regardless of load. I can stomp on the skinny pedal to force a downshift, and that will work, but until then it's lugging really bad even to the point of torque converter (?) rattle. This really sucks when towing a car trailer! I have already adjusted the TV cable per a video I found online.
2a. Under moderate to heavy acceleration at about 45-50 MPH, just after shifting to 3rd, trans will downshift to 2nd, then back to third in a couple of seconds.
I suspect TPS. I've read some troubleshooting info. on this, but I'm still unclear if I can test using standard multimeter on my TPS. Will the probes push in from the outside of the TPS wire connector while attached, or is there a better way to do this? Sounds like it needs to be tested on the vehicle. If I find dead spots in the voltage and want to replace the TPS, which companies make a good one? I see Mopar-labeled ones for around $75, then all sorts of other brands like Wells, Walker, Delphi, Autex, Airtex, Standard Motor Products, etc. for anywhere from the $40 range down to the $20 range. Obviously, Mopar is the most expensive. Are others good, or should I buck up on this one?
Thanks in advance for any help and/or recommendations!
