Thermostat
ramthis9501
Oklahoma
5.2 V8
I'm going to replace the thermostat when I do the plenum, I want to go at a cooler temp, thinking about 160. What's better though, 160 or 180?
txbass06
NE Texas
5.9 Magnum
180
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Second that ^^
ramthis9501
ramthis9501
Oklahoma
5.2 V8
So what are the significant pros of running cooler?
joetama
Ohio
Cooler as in 160? I would say little to none. Too far out of the normal operating temperature of the engine.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Lowest you would want to go is 170 and depending on the winters you may get a CEL for slow warm up.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
Definitely do 180. You don't have a need for anything lower and you would regret a 160 in the winter.
Funny you mentioned this though as I just swapped a 180 in my truck last night and deleted the clutch fan.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
And I went with 180, the truck was running over 200 on the way home earlier... way to hot i think
BMRbrnSNRbrd
Norman, OK
The 4th gens actually come with both an e-fan and a clutch fan. If you install a 180 and lower the factory e-fan settings with a programmer you can delete the clutch fan and it's parisitic drag on the engine.
BMRbrnSNRbrd
Norman, OK
Seems to be holding up fine. We'll see on Friday when I get to Vegas how it does there.
