Trans cooler line blowing off
01rammer1500
Has anyone had trouble with the upper cooler line poping off and draining their fluid? I had mine do it to me today and got lucky and all seems fine. Why did it happen? It shouldnt have that much pressure?
mda8569
Vandalia Ohio
5.9 magnum
Yea, that dont seem right, lol. My truck has the cooler up front, and the upper hose is a check vavle and known to leak, but shouldnt be popping off. What type of connector do you have? Should be pretty obvious why its popping off. The only thing I can think of is the valve isnt working properly and causing pressure build up. I think most guys here just delete it with a reg hose. I think you have to let the trans warm up longer or something like that.
01rammer1500
The trans cooler for me is part of the radiator. The line physically poped off the fitting and drained all most all fluid. I replaced the oem line with a hose and 2 clamps, but it popped off again. I was on a 150 mile trip. The trans was warm when it came off both times
mda8569
Vandalia Ohio
5.9 magnum
Ah ok. So are the threads stripped in the rad? What type of fitting is it thats popping off?
01rammer1500
No. The brass fitting that the hose goes on to is not stripped.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I'd be questioning if the cooler(s) clogged.
01rammer1500
Can i go to an afterarket cooler and leave the oem one unhooked? Also since im worried about my trans, im probably going to be putting a new tq converter in. Any recommendations?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yeah you can leave the OEM one(s) unhooked. I'm actually running my OEM auxiliary cooler and an aftermarket one.
I don't know what is good with regard to TCs.
