Hello, I have a 2000 Dodge 1500 2WD 46re transmission. Recently I dropped my transmission because my overdrive went out. The tail of the transmission basically melted together, mainly because I think it was my cat was clocked, so I hollowed out the cat before I installed my transmission back into my truck, but when I was putting the transmission back into my truck i realized that the transmission lines run very very close to the exhaust manifold. I kinda knew that it was going to be a problem from the begging, but I just ran with it because i didnt mess with anything when taking the transmission out. So at first I drove home from my shop which is about a 20 min drive, and about 10 15 minutes into the drive my transmission overheated. So i let it all cool down over night, and I went under the truck and moved the lines as far away to the exhaust I could. Then I was able to get a little longer (while i was driving steady at 50+, but when i was in town it would over heat very fast). I went on a trip to texas with my truck with the overheat problem, and it overheated a few times. When i was in texas I got a aftermarket transmission cooler, and i removed the check valve in the transmission line, and now it still over heats. When i got back from my vocation i drained all the transmission fluid out and put in new ATF+4 and i still have a overheating problem. But im kinda noticing that sometimes when the transmission says that its overheated my transmission shifts flawlessly. So i really dont know what to do at this point, any suggestions?
