jsmith
Ok decided to take the Ram for a drive last night after work and drove normal for around 5 minutes then stalled at a light. It restarted after a couple minutes and then did it again a few miles down the road and eventually restarted and got her home. I was able to replicate it after about 5 minutes sitting in the driveway.
No codes, can hear fuel prime when trying to restart, coil ohmed out good. I'm thinking crank position sensor or is there something else I should check before I start throwing parts at her?
At work so won't be able to do anything until afterwork but was going to pick up ckps on way home unless yall think I should try something else first.
