Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Truck starts won't run
This is a discussion on Truck starts won't run within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
I'm a fan of the forum. I find it helpful so maybe someone can help me. I have a 99 ...
Sponsored By: Moe's Performance
Reply
Old 01-26-2013, 09:46 AM   #1 (permalink)
Ram Year: 1999
Engine: 5.9 magnum
Default Truck starts won't run
I'm a fan of the forum. I find it helpful so maybe someone can help me. I have a 99 ram magnum motor. 5.9, new pick up coil, plugs, wires , cap and rotor. A new IAC. I've tested compression. 150 acrossed the board. Feul pressure is 50. I've tested view data on TPS, perfectly responsive through out all throttle range. Good vacuum on MAP and correct resistance through the crank sensor. Haven't checked engine timing, don't have ant noids to check injector pulse. However the smell of gas is present. No lights on dash. Problem with truck; lost power on highway slowly. Exited highway, at the park and ride it would barely stay running. Got a cylinder 5 misfire code. Reset the computer and it drove fine for 5 miles and then stopped moving. Started barely running, got engine ping and it quit. Now it sits in the drive way only starting at WOT. Won't run but starts easily. It may stay running for 5-10 seconds sucking air hard and fowling out with fuel. Has symptoms of several problems, though I've tested each or replaced with no fix! Ready for the junk yard.
Sponsored Ad
Register to remove this ad.
Achevyindodgeclothing is offline   Reply With Quote
Reply
Bookmarks
Tags
won't run
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my truck in the toy truck parade in philadelphia deuceram Exterior 16 07-14-2013 08:04 PM
My truck CAN do it! (truck camper) **pics** cheapbeater Photos & Videos 16 07-25-2010 08:48 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
