Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Truck won't heat up
This is a discussion on Truck won't heat up within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Truck will not heat up, has brand new heater core and I'm on my 4th thermostat. All started after replacing ...
Sponsored By: Moe's Performance
Reply
Old 12-08-2016, 09:32 PM   #1 (permalink)
Ram Year: 1998
Engine: 5.9
Default Truck won't heat up
Truck will not heat up, has brand new heater core and I'm on my 4th thermostat. All started after replacing my plenum gasket. All parts from dodge. Made sure to burp the system and checked all fluids. Any ideas?
Sponsored Ad
Register to remove this ad.
mok4200 is offline   Reply With Quote
Old 12-08-2016, 09:42 PM   #2 (permalink)
Ramtech2319's Avatar
Ram Year: 2014
Engine: 5.7
Default
Year , engine please
Ramtech2319 is offline   Reply With Quote
Old 12-08-2016, 09:57 PM   #3 (permalink)
Ram Year: 1998
Engine: 5.9
Default
Oops, 2001 5.2l auto 4x4
Old 12-08-2016, 10:04 PM   #4 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
If the truck is refusing to get up to operating temperature, you need to verify the gauge reading by either feeling a radiator hose with your hand, or a thermometer. If the radiator hose heats up after about 10 minutes of idle, replace your coolant temp sensor. If the radiator hose doesn't heat up, you need to check for flow from the water pump. That requires taking out the thermostat and running the engine with the radiator cap off. You may be able to test it without removing the thermostat, but there is no guarantee. With the engine running, look into the radiator cap hole and watch the coolant level as you rev the engine by hand. The level should drop when you rev the engine and rise when you let off.
If it doesn't remove the thermostat and try again, or if its already out, you are looking at a new water pump. You could try flushing it before replacing the water pump.
Old 12-08-2016, 10:44 PM   #5 (permalink)
Ram Year: 1998
Engine: 5.9
Default
I drove it around for 30 mins and the heater hoses were hot but not too hot to hold onto. I'm going to try to replace the upper and lower rad hoses then try to take out the thermostat and see what happens, thanks for the advice
Old 12-09-2016, 10:32 AM   #6 (permalink)
Engine: Magnum 360
Default
The heater core hoses wont be HOT if the core or one of the adapters/lines is plugged or you're running a thermostat at 180* or less.
Whats important is the upper radiator hose. We might be on different pages here. Is your cab heat not getting hot, or is the engine coolant not getting hot?
Old 12-09-2016, 06:17 PM   #7 (permalink)
Ram Year: 1998
Engine: 5.9
Default
Both. Last week I got a "too cold for too long" engine code and after that I put in my dodge thermostat, same result. The cab also has very very mild heat, would guess maybe 90 degrees blowing. The upper radiator hose I should replace, when I was changing thermostats it was pretty flexible..
Old 12-09-2016, 09:15 PM   #8 (permalink)
Engine: Magnum 360
Default
It is a slight possibility, if someone just put straight water in at some point and ran it like that for awhile, that there is a type of scale buildup that is preventing heat from transferring to the coolant. At this point, i'd put in a coolant flush additive and run it without the thermostat until it gets up to operating temp for at least 20 minutes, or about 100 miles, whichever comes first. The flush and reverse flush the engine block and forward flush the rest.
Old 12-14-2016, 04:10 PM   #9 (permalink)
Ram Year: 1994
Engine: 5.9L6
Default
Make sure you are installing a Mopar T stat and its being installed the correct way. The thermostat is the ONLY thing that can cause this issue
__________________
1995 1500 4x4 318 100k Stock
1994 2500 4x4 diesel 240K 4x4 Auto. New Cummins LP,Trident fuel lines, Tork Tek OFV, , Diamond eye 4" turbo back, 37337 Upgrade. 240K (Next upgrade hydroboost swap)
alanack6795 is offline   Reply With Quote
Old 01-02-2017, 08:29 AM   #10 (permalink)
Ram Year: 1998
Engine: 5.9
Default
Spring is in the down position, and it is direct from the dodge dealer. I'm going to take it out soon, and then put it in boiling water to make sure it is opening.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New 2003 Ram owner... Truck has no heat,smell coolant from vents EvolutionVIII Engine & Performance 4 06-04-2014 09:14 AM
Low heat in my 01 ram Guyj Interior 7 01-31-2014 09:34 AM
Heat sheild under the truck all messed up sullivan General Discussions 0 08-23-2013 01:15 AM
Heat and Heat Vents Mega Mike Tech Info 11 01-08-2013 06:58 PM
Heat went in the truck, need some help ol'red02 Tech Info 3 11-26-2012 08:53 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
