Turboing a 5.2
MikesRammin
New Carlisle, Ohio
5.2 Magnum
Now a few months ago I remember watching an episode of trucks where the turbod a mid 90s Ford Lightning and they placed the turbo back behind the cat. I was thinking about turboing my ram for some little extra ponys and a cool factor. Now I don't have any experiance with turbos but I have a general idea of what I need. I know I need the flange for the turbo to weld to the exhaust. I wanna weld a piece of steel to the flange and then to the frame for support ducting up to the engine for the air. I'm gonna just run a straight pipe for the exhaust an oil line to the engine a boost gauge. Now do you guy have any idea what PSI I should run on it? I want to run as much psi as I can without having to do any tuning on the computer. Also what typer of turbo should I get? Any of you guys out there ever turbod a gas ram?
Mopar1973Man
New Meadows, Idaho
Well the little tidbit from the diesel relm...
I know I'm comparing apples and oranges but...
I know the 24V Cummins is 16.3:1 ratio (or 17.0:1 for HO). But static compression pressure is right around 450 or so. So now you add a turbo charger and 35 PSI boost the cylinder pressures will rise up to 1,100+ PSI
Now there is another problem your going to have to deal with.
From Wikipedia about Autoignition temperature...
The autoignition temperature or kindling point of a substance is the lowest temperature at which it will spontaneously ignite in a normal atmosphere without an external source of ignition, such as a flame or spark. This temperature is required to supply the activation energy needed for combustion. The temperature at which a chemical will ignite decreases as the pressure increases or oxygen concentration increases. It is usually applied to a combustible fuel mixture.
So adding a turbo will cause preignition for a gasser so you'll have to look into different fuels that have a much higher octane level to prevent pre-ignition from occuring.
I'm not saying it not possible but a lot of factors change when adding a turbo charger.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have not looked into it much for the 318s but I know on the 5.7s you open up a large can of worms. Most gassers on stock internals top out at 10 psi at the most and thats pushing them normaly unitl you go fordged. You will also have to drill and tap the oil pan for the turbo oil lines, change around the intake system and modify the exhaust. The 2nd gen guys will chime in though knowing they have possibly already looked into this route.
Badger
Bettendorf, IA
It's not worth the effort. If you want more power check out Hughes performance. Save the turbo for diesels and ricers.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Found this on the interwebs *NOT MINE*
This is the mock up on my cuz truck. He wanted more power to pull 35" tires with 20" wheels. It's a t-60 turbo from a STS kit. The turbo flange pipe and wastgate is from the STS kit that was on my HD.
24# injectors and reflash by PPH. We're not lookin to get craze, so boost will be set at 5psi.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The computer is the main thing for this to work, same as Michael stated its gonna want to knock bad.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
being a 94 the computer would need to be flashed if I am not mistaken, but I usually am
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I figured it would either have to be sent off or contact a person who would make a replacement. Being that year would it be easier to come by a doner 2500 with a CTD and do a swap?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You can change the psi by swaping the waste gate spring
MikesRammin
MikesRammin
New Carlisle, Ohio
5.2 Magnum
If I put a diesel turbo on there would that work better for my application because its set to kick in at a lower RPM? Since the most RPM it will ever see is probably around 4500. Also would that work better since its coming of 5.9 so I think it would be more around the correct size since its a little bit more cubic inches than my 318. Also what psi is the cummins turbo set at? I would like to run a set up thats all internal in the turbo so that way I don't have to fiddle with the exteral waste gate blow off valve and such.
MikesRammin
MikesRammin
New Carlisle, Ohio
5.2 Magnum
See I would like to be able to buy from hughes but I'm working on a very limited budget so it would be cheaper for me to piece together a turbo kit.
1Popeye
