Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Unknown Problems.
This is a discussion on Unknown Problems. within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Whenever I accelerate hard (like when I pass somebody on the highway) I've noticed that my check engine light starts ...
Sponsored By: Moe's Performance
Reply
Old 12-26-2016, 04:15 PM   #1 (permalink)
bluwarguy's Avatar
Ram Year: 1997
Engine: 5.9 Magnum V8
Default Unknown Problems.
Whenever I accelerate hard (like when I pass somebody on the highway) I've noticed that my check engine light starts to flash. The check engine light is also on and gives me 2 codes: 12 and 43. My oil consumption is awful and I have to constantly buy oil for my truck. Sometimes when starting it in the cold, it doesn't like to stay on and I have to slightly give it gas for about a minute and it'll stay on. If not then it sputters and dies. Are any of these problems related and what could the main problem be?
Sponsored Ad
Register to remove this ad.
__________________
Straight Piped
Stant 180 Deg. Thermostat
Spectre Throttle Body Spacer
Mota 14x3 Air Cleaner
bluwarguy is offline   Reply With Quote
Old 12-26-2016, 04:26 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 318
Default
Oil consumption followed by cylinder misfire (Generally what the flashing CEL means) on a dodge means its time for the plenum.
Code 12 just means the battery has been disconnected within a certain number of ignition cycles.
Code 43 could be a couple things but usually is random multiple cylinder misfire.
I'd go with the plenum but you can also check your ignition coil.
Measure the resistance of your coil from the tower to a pin on the input you should get about 12k-15kohms. Between the two input pins should read about 1-2ohms. If either is wildly off, replace the coil.
Old 12-26-2016, 04:31 PM   #3 (permalink)
bluwarguy's Avatar
Ram Year: 1997
Default
so Code 43 could be fixed with the plenum kit?
__________________
Straight Piped
Old 12-26-2016, 04:42 PM   #4 (permalink)
pajeepman's Avatar
Ram Year: 2003
Engine: 5.9 magnum
Default
Oil loss without visible leak is almost certainly a plenum issue. I replaced mine with an aluminum one from ebay. No issues for 4 months so far.
Sent from my SM-J320P using Tapatalk
pajeepman is online now   Reply With Quote
Old 12-26-2016, 11:18 PM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Yes start with plenum and in the process of doing it do a tune up as well
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 12-28-2016, 03:11 PM   #6 (permalink)
bluwarguy's Avatar
Ram Year: 1997
Default
I bought an OBDII reader and found that the code is specifically P0308, so Cylinder 8 is the one misfiring.
__________________
Straight Piped
Old 12-28-2016, 03:43 PM   #7 (permalink)
Engine: Magnum 318
Default
Cylinders 7 and 8 are the most common ones to go with plenum issues.
Old 12-29-2016, 04:19 PM   #8 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Cylinder 8? Plenum
__________________
Old 12-31-2016, 02:00 PM   #9 (permalink)
pajeepman's Avatar
Ram Year: 2003
Engine: 5.9 magnum
Default
Plenum guaranteed. Same problem i had minus the not staying running.
Old 01-02-2017, 12:44 AM   #10 (permalink)
Ram Year: 1999
Engine: 5.9L
Default
We recently bought an aluminum plenum kit from Hughes engines and it included all gaskets, bolts, etc. needed for $142 total for shipping and the kit.
Truemagnum15 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
unknown hose jasonb Engine & Performance 5 02-01-2016 09:47 PM
Unknown plug jabartram General Discussions 13 11-16-2015 05:47 PM
Unknown connectors? smoothee Interior 5 09-18-2015 11:22 PM
Unknown chime acejones General Discussions 5 08-06-2015 09:48 AM
unknown whine JnJ's Hemi Engine & Performance 24 04-17-2013 05:26 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
