Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Unknown Problems.
This is a discussion on Unknown Problems. within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Personally, I'd recommend spending the few extra bucks and upgrading the kit to the Fel-Pro gaskets. There's no comparison between ...
Sponsored By: Moe's Performance
Reply
Old 01-02-2017, 03:42 PM   #11 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
Personally, I'd recommend spending the few extra bucks and upgrading the kit to the Fel-Pro gaskets. There's no comparison between El Cheapo and Fel-Pro.
Sponsored Ad
Register to remove this ad.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
American Racing Nitro, K&N open element, modified 50mm, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, tuned by Flyin' Ryan, Hughes plenum repair, steering stabilizer, 4x4 Posi-Lok
Yeret is offline   Reply With Quote
Old 01-04-2017, 10:59 AM   #12 (permalink)
bluwarguy's Avatar
Ram Year: 1997
Engine: 5.9 Magnum V8
Default
How difficult is it to replace the plenum yourself? What kind of tools will I need? If it's not something I'd be able to do myself, what's the average cost to have a mechanic do it?
__________________
http://i987.photobucket.com/albums/ae356/wwiiiprod/yeeyee_zpswapzodeh.jpg
Jegs Off Road Y-Pipe, Stant 180 Deg. Thermostat, Mota 14x2 Air Cleaner, Spectre Breather Filter, MSD Blaster Ignition Coil, BWD Distributor and Rotor, Champion Spark Plugs, B&W Gooseneck Hitch, 245/75/16 Cooper Mudclaw
bluwarguy is offline   Reply With Quote
Old 01-04-2017, 02:34 PM   #13 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
Its pretty easy to do yourself, I had mine done in 2 hours, but I took a bunch of extra time to really clean off the gasket surfaces before replacing everything.
The only tools you need are an in-lbs torque wrench, 1/2in sockets, 4in and or 8in extension, a flathead screwdriver, a gasket scraper (makes life easier), coolant and oil for a change, and a fuel line disconnect set (its possible to work around this, but for the price its worth it to just buy a set).
If you go with the hughes repair kit everything is listed out. But the just of it goes like this. Disconnect the alternator, unbolt the alternator and A/C compressor bracket and move it aside. Remove the air intake down to the throttle body, unplug all the electrical connectors from the throttle body. You can either unbolt the TB or just remove the cables attached to it (I found it easier to just remove the 3 cables and leave it bolted to the intake). Then unplug the electrical connectors from the injectors. To make your life easier, undo the harness clips that hold the electrical harness to the valve covers and move the harness out of the way. MAKE SURE YOU CLEAN ALL THE CRAP THAT IS SITTING BETWEEN THE HEADS AND THE INTAKE. Now you have 14 bolts around the perimeter of the intake, their locations are listed on the hughes diagram, once all of these are out, you may need that flat heat to gently pry up on the front of the intake t break it loose. After the intake is off, the plenum pan is on the bottom of it, it has 12 or 16 bolts I think. After you have it all apart scrape the old gaskets from the heads, intake and block. Install the plenum pan and gasket, install the intake gaskets and reverse the order of removal while following the torque instructions listed on the hughes kit.
After you have finished, change the oil unless you drained the coolant first, as a bunch of coolant has leaked into the engine.
dudeman2009 is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
unknown hose jasonb Engine & Performance 5 02-01-2016 08:47 PM
Unknown plug jabartram General Discussions 13 11-16-2015 04:47 PM
Unknown connectors? smoothee Interior 5 09-18-2015 10:22 PM
Unknown chime acejones General Discussions 5 08-06-2015 08:48 AM
unknown whine JnJ's Hemi Engine & Performance 24 04-17-2013 04:26 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
