E4ODnut
- Oct 21, 2016
- 31
- 3
- Gibsons BC Canada
- 1995 Dodge Ram 2500 4x4
- 8L V10
The CKP and CMP sensors for these engines seem to be almost impossible to get now. I'm checking into the possibilities of getting some housings custom machined out of aluminum stock and using the Allegro ATS617LSGTN-T gear tooth sensor but I need some more details on the dimensions of the trigger wheels (tone rings)
If anyone has a crankshaft and a cam sprocket that they can check, I'd like to know the outside diameters, the width of the face, the length and depth of the notches. Also the installed air gap between the sensor faces and the wheel itself would be good to have.
Thanks.
Thanks.
