realflow100
- Jul 24, 2016
- 13
- 0
- 1999
- it is 1500 model 5.2L stock
hello my parents dodge ram 1999 1500 5.2L has been having some problems
It runs perfectly when cold after its warmed up it wants to die unless we keep it revved but it starts getting rougher and rougher and sounds like its going to fall apart shaking a lot.
if it dies and we start it. it starts easily but still runs rough while warmed up and wants to die if we let it go to idle
Every time we dont use the car for about a month we take the battery cables off because it has some sort of draw on the battery that doesnt cease.
The oil smells like gas pretty strongly in the oil tank. There seems to be the correct amount of oil though. Right in the middle of the "safe" mark
The oil gauge in the dash is not agreeing with the dipstick and reading about halfway between the middle and "max" lines.
also the speed MPH gauge is stuck at 0MPH
For a few weeks the car wouldn't want to start after we let it sit after dying for a month or so.
It would sputter and sputter occasionally but never start.
We used almost a fourth thing of engine starting fluid directly into the air intake before it eventually started and ran poorly with lots of white smoke and mixture of white and black smoke at first.
About 10-15 seconds later it was running just fine we drove to the store and got groceries but on our way back it was struggling and really sputtering
Now today it's starting just fine but doesnt want to stay running when warmed up
The transmission fluid seems just fine though.
also it seems the check engine light isnt on.
but the ABS and brake lights are on continuously for some reason.
What could be the cause for so many issues?
It just spontaneously started doing this after a few years of running just fine.
but we don't use the vehicle very often.
also I believe once the engine is started. before it warms up but when its almost warmed up and not yet running rough or wanting to stall.
The rpm is about 650RPM and It sounds like I can hear the spark plugs individually firing. sounds like clicking almost but its not very noticable is that normal?
Theres no unusual amount of exhaust or even visible exhaust when running for about 30 seconds. no color or anything even when its about to die
At first though the exhaust is dark right when its first started.
I attempted to clean the air intake with a toothbrush and a rag and there was black smear on it.
I also notice a "sssssssing" sound when the AC is turned on. or when the engine is slowing down from a rev. that sounds like constricted air
Also occasionally while trying to start the engine. The starter will suddenly halt instantly with a mechanical "clunk" then immediately continue to crank and start the engine.
it was happening a lot while we were trying to get the engine to start when it didnt want to start for a while but still sometimes happens.
It calls for regular gas but we added an octane booster/cleaner mixture to the tank and thats i believe what mostly got the car to start up in the first place when it wouldnt want to start after sitting.
Could we try running the medium gas and see if it improves? It seems theres far too much advance engine timing on startup
