Ok first of this will probally be a long post.
I have been banging my head trying to figure out a problem. since i got this truck a few days ago.
I have a 98 ram 1500 SLT Laramie 4x4 with 318.
After about 30 seconds after start up the idle goes up and down between 400 and 800.
I can rev it to the moon if i want and it is smooth when cold.
It drives good for the first couple minutes also when it was cold. Once it gets warm it starts to pop and kinda like back fire thru the exhaust and i have very little power.......i can put my foot down and it will downshift then take off but still a little rough. Once i let of it is back to popping and back fire. Even at this point i can put it in neutral and rev it just fine ( maybe small popping as it comes back down in rpm's )
Okay now what i have done all ready.
New plugs (stock champion)
New wires (autolite)
New cap and rotor
I routed the wires per the tsb
I cleaned the IAC
Check that the TPS is working correct.
Removed the TB and cleaned totally. New gasket.
New upstream 02 sensor (Denso)
Cat converter was gutted allready.
Cut pipe in front of muffler to eliminate that it is clogged.
Tested fuel pressue ( about 46-47 key on not running. also the same running)
Pulled all 8 plugs(pictures to be added)
I found 1 broken vacuum line and fixed that. I haven't gone thru all the vacuums yet to look for leaks.
Any other ideas.
Runs very smooth untill it starts warming up. (maybe a couple minutes)
After it warms up it starts it's missing sound....if i give it alot of gas it goes sorta smooth.Once i let off at all it starts doing it again.
Again at any point i can put in neutral and rev to the moon if i wanted to.
the other plugs are the same......well 3 and 6 are the same and the rest look alike.
New cap and rotor
I cleaned the IAC
Any other ideas.
