Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
what is the correct transmission?
This is a discussion on what is the correct transmission? within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Hi guys, i want to put a 4 speed tranny on my 96 because it sucks to have only 3 ...
Like Tree4Likes
Sponsored By: Moe's Performance
Reply
Old 05-19-2017, 07:47 PM   #1 (permalink)
Ram Year: 1996
Engine: magnun 5.9
Default what is the correct transmission?
Hi guys, i want to put a 4 speed tranny on my 96 because it sucks to have only 3 and i get very bad gas mileage as well. i know that having a 5.9 under the hood isn't a gas saver but if had a 4 speed the truck will feel lighter and the rpms won't be as high always. Now, take in count my truck is not a mpfi , it has the older TBi system. what year should i be looking for in the junkyards to make a plug and play swap? do i need to change the differential also?
thanks in advance for the info.
Sponsored Ad
Register to remove this ad.
rogelioifmradio is offline   Reply With Quote
Old 05-20-2017, 01:12 AM   #2 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
I'm just going to say that it is very weird that your 96 5.9 is a TBi because my 96 5.2L has MPFI.
Also if I'm not mistaken the only automatic transmission for our trucks is the 46RE. I don't know much about the manuals if that's what you have. I do also find it strange that yours is only a 3 speed. Just looked it up. 46RH and 46RE are both 4 speed autos. The only 3 speed autos I found was last used in a 1991 Jeep.
__________________
1996 Dodge Ram 1500 5.2L
Plenum Plate fix with Fel-pro gaskets
NGK V-Power plugs
MSD 8mm Wires
MSD Blaster Coil 8228
Accel Cap and Rotor
After Market Tow Mirrors (Don't care for the flip up but I'm happy they don't try to show me my own reflection)
Shadow_Death is offline   Reply With Quote
Old 05-20-2017, 02:07 AM   #3 (permalink)
Ram Year: 1996
Engine: magnun 5.9
Default
I have checked the invoice from the dealer cause i thought maybe the P.O. changed the motor, but no. invoice says 5.9 tbi, 3 speed auto.
as far as i know, mpfi was not available till late 1996 en Mexico, i don't know why, if it is made in Mexico. now the dealership can't find any records of my truck with my VIN, the computer says it doesn't exist. so it is a PITA every time i go to the parts store cause their computers don't show it either. i guess i have to ask for 1991 parts, but in that year dodge ram didn't use the 1500, 2500, 3500 series
anyway, i am lost in Mexico with my truck that was made in Mexico...pff
so if was to change the tranny for the 4 speed auto, the 46RH will fit directly?
Old 05-20-2017, 03:49 PM   #4 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
The bellhousing the is same, you can get any Dodge 46RH transmission for the V6 or V8 engines.
Whats strange is the TBI, I've never heard of TBI on the gen II trucks, I've never heard of any 3spd on them either. I have the service manuals for every truck from 95 to 01, and all of them list MPFI. Something is very strange with what you have going on, Dapepper would be able to shine some more light on it.
I would suspect that someone put some strange components in your truck, it wouldn't surprise me to learn that you have an LA engine in there instead of a Magnum. What is your VIN number?
__________________
I fixed it until it broke.
Old 05-20-2017, 04:32 PM   #5 (permalink)
Ram Year: 1996
Engine: magnun 5.9
Default
here it is!
Old 05-20-2017, 04:58 PM   #6 (permalink)
Engine: Magnum 360
Default
I've pulled up various VIN breakdown sheets, your truck doesn't make any sense. The 8th digit is a 7, that corresponds to the 5.9L 24V high output turbo diesel, but that engine was only put on the 2001 model year.
You'll have to get the Vin from another location on the vehicle. Pop the hood and when looking at it from the front, on the left side of the radiator facing front on the vertical radiator support there is a blacked out vin tag. It has a large group of 3 alphanumeric codes, but there is a VIN on there.
__________________
Old 05-20-2017, 05:02 PM   #7 (permalink)
Ram Year: 1996
Engine: magnun 5.9
Default
its the same vin that has the metal tag as well, i will try to locate the one you say as soon as i get home, thanks
Old 05-21-2017, 12:08 AM   #8 (permalink)
Ram Year: 1996
Engine: magnun 5.9
Default
Here is what i found
Old 05-21-2017, 02:37 PM   #9 (permalink)
Engine: Magnum 360
Default
So thats legitimately the VIN. If you can poke around and find the VIN on the engine that will end all suspicion that someone swapped an engine in.
I'm surprised to see that engine code in there though, it just doesn't fit, unless they changed what it meant at some point after the manufacture of this truck and 2000.
__________________
Old 05-21-2017, 05:14 PM   #10 (permalink)
regularcab2500's Avatar
Ram Year: 1997
Engine: 5.9 Magnum
Default
So you have a tbi carb on your engine? Can you take a pic of your trans pan? It sounds like someone took a 5.9la and 727 a swapped it in at some point. If you take a pic of the trans pan and top of the motor we could help at least identify.
regularcab2500 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Is this correct? Cannot be. 8k lbs? E462ko Towing & Hauling 14 04-16-2017 12:33 PM
Which WIX XP is correct? GsRAM Heavy Duty 11 01-24-2017 08:04 AM
correct used Transmission ? badluck General Discussion 4 01-04-2017 09:56 AM
Transmission ID & Correct Rebuild Kit Maven1 Tech Info 1 05-13-2016 09:48 PM
is this correct? ralaubach Exterior 3 10-31-2014 02:13 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
