What gears to use ?
Bigred121787
Plan on running a 37in tire wat gears should use? Was thinkin 456. Street driven truck w slight mods thanks
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Try and find 4.88s. 4.56 will do, but 4.88 will more closely match the stock tire/gear combo.
Merc225hp
NA
truck
gas
I took sometime yesterday to see what up with the 4.88 ratio I was told NLA people so SOL.
regularcab2500
Buffalo
5.9 Magnum
9.25 gearbox wont fit 4.88s others on here have told me 4.56 is the smallest gear possible for the 9.25" differential which i have in the front
Sent from my SCH-I510 using Tapatalk 2
Merc225hp
NA
truck
gas
They are not the same 9.25 diff's.
regularcab2500
Buffalo
5.9 Magnum
Yeah guess i didnt realize he has a 2nd gen anyway so its not anywhere near the same lol..
Johnn123
Ontario
For 37's I'd be looking at 3/4ton or 1ton axle swap and 4.88 gears. They should be readily available for Dana 60/70 axles. That way you wont be replacing almost every front end part on a yearly basis, if not more.
