lumpus
- Feb 20, 2012
- 3
- 0
- 1998
- 5.9l magnum
So I have a 98 ram 1500 4x4 5.9 magnum. Thing sat for like 2 or 3 years got it real cheap. 101k miles. Charged the battery and it started perfect ran for about 2 mins and studderd and died. Put fresh fuel in it cleaned the tank replaced the fuel pump temp sender spark plugs tps still does the same thing put my scanner on it and it says its still to cold to use the o2 sensor even though its above 100 degrees usually when it starts to studder. I'm at my wits end with this thing. Any ideas. Was thinkin might need a the pcm to be updated but idk.
