sirtokesalot
- Jul 6, 2017
- 4
- 0
- 1998
- 5.3
i have been trying to figure out why the speedo is not working in my grandmothers van she has a 1998 dodge ram 1500 conversion van. it had a check engine code for the speed sensor we changed both the sensor in the tail of the transmission and the sensor on the rear diff. speedo still only works intermittently it never shows the actual mph and is moving around alot like say if im really doing 45 the speedo is showing around 20 to 40 mph bouncing around in that range it sometimes cuts out completely as well. the speedo will also cut out if the brake is applied. the abs light and brake lights are not lit. the check engine light is still coming on but my code reader claims no codes in the computer when i attempt to read it. i followed the wires from the rear speed sensor up to this computer module near the brake lines i think it may be an abs module and verified the wires are not broken between the sensor and this module using a volt meter but i do not know what path the wire takes after leaving that module as i cannot locate any kind of pinout of that module anywhere.does anyone have acces to wiring diagrams for the 1998 dodge ram 1500? im looking for a schismatic for the abs rwal module with pinout of the connector if possible. im trying to figure out what wires would have to be jumped to allow the speed signal to bypass the abs module and go strait to the cluster.
