After market infinity speakers
swungspeedz
I have had them for a while and this problem for a while whenever I turn the radio up to loud they cut out, some people say you have to run a internal amp with them and the dodges stock speakers come with the little black amp hanging on the stock speakers, how would I use that with the after market speakers or would I have to get another amp to bolt on the door and run them to each speaker? Someone please help.
Sent from my SPH-L710 using Tapatalk
MagSport
South Carolina
You can wire the outputs out of the stock amps to the aftermarket speakers and remote mount the Amps on the door.
swungspeedz
swungspeedz
What wires are they there are like a whole bunch of them and then there are just a ground and power going to the after market. Can you tell me which ones or use pictures? Thanks magsport
swungspeedz
swungspeedz
Anyone help?
jsmith
Texas
So I just gave the right front input and put them with the power? And the left front input with the power?
What are you tryng to do exactly? Wire stock amps/speakers with aftermarket headunit or wire the stock amps to aftermarket speakers?
swungspeedz
swungspeedz
Stock amp to after market speakers. My infinity speakers. Need a response as soon as possibe.
swungspeedz
swungspeedz
whst wires shohld I run to use the infinity amp with the speakers
connected the 2 amps too and still cuts out at 20-30 volume
swungspeedz
swungspeedz
I was using black to negative and red to positive but the speakers kept cutting out cause they were not getting enough power what wires do I run to use the built in infinity amp
jsmith
Texas
Sent from my SPH-L710 using Tapatalk[/QUOTE]
Pretty sure you have them hooked up right, before I changed headunit and did away with the stock amps that's how I had them wired. Maybe the stock amps have a builtin cutoff and they were overheating and triggering it? Never turned mine up very loud when I had stock so not sure though
swungspeedz
swungspeedz
Thanks for the input man, I been trying all day my one friend said I need to either run a bypass for it or run speaker wire from the radio down to the speaker only way they would work. But I thought that I could bypass that some how. Or use the built in infinity amp?
jsmith
Texas
I think he may be right and you just need to bypass the stock amps, it might be worth a try to see if it eliminates the cutting out at least.
Merc225hp
NA
truck
gas
Yes bypass the factory amp. Just run it off the deck.
swungspeedz
swungspeedz
Do you think I might need to just unplug the blue wire from the back of the radio for the amp? Or I need to by a bypass harness?
