battery drain
Greehn
5,9 Magnum
Hello
So I've figured I have about 3,1amp drain from the I.O.D circuit.
Do anybody have a clue on what can pull that many amps?
Any tips would be of great help!
What I did:
I measured over minus-pole and minus cable: 3,1amp
Removed 50amp main fuse: 0amp drain
Reinserted 5amp and removed I.O.D fuse: 0 drain.
I disconnected the radio, still 3,1Amp
So thats how far I've gotten so far
G
Greehn
5,9 Magnum
Found this cable ending up in the over head lights unit. Dont know what its for.. Anyone?
And also the lights inside the cabin is always on.. Anyone see any faults?
Sent from my E6653 using Tapatalk
SilverStreak88
Houston, Texas
5.7 Eco Gasser
It appears that the previous owner had something up there, follow it down and see where it goes.
Sent From 1 of Many Samsung Devices
GoldDot
Just keep pulling fuses and wiring harness connectors until you find it.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
Your truck has an aftermarket sunroof? Did you find out where those connectors went? I bet it has something to do with that sunroof up there!
lasse452
