pwaite92
2001 1500 5.9 V8
I notice quite a bit of dimming from all my lights when I'm driving at night.
If I drive without headlights on my volt meter pegs out in 10 minutes or so and causes the "check gauges" MIL to come on.
If my headlights AND a/c are on, the volt meter dumps to nothing and causes the same MIL to come on.
If just my lights are on it hangs around 14 volts.
It's got dual batteries with an isolator that were there from its forest service duties.
noticed the other day that the second battery wasn't hooked up. put a volt meter on it and it read like 1-2 volts. hooked it up with it running and tested it again and it only read 12 volts.
I suspect the isolator or the alternator is not doing it's job well.
Is there a good alternator upgrade out there?
There will be lots of accessories in the future and I would like some serious power output.
Thanks
Thanks
