Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Audio & Electronics
Audio & Electronics
Fog/High Beam Issue
This is a discussion on Fog/High Beam Issue within the Audio & Electronics forums, part of the 2nd Gen : 1994 - 2002 category!
First off, this is my first time ever being in a forum, so if I am doing something wrong please ...
Like Tree1Likes
  • 1 Post By dapepper9
Reply
Old 11-06-2016, 10:21 PM   #1 (permalink)
01RamSport318's Avatar
Ram Year: 2001
Engine: 5.2
Default Fog/High Beam Issue
First off, this is my first time ever being in a forum, so if I am doing something wrong please inform me.
I have had bright yellow highs and lows for about a year now and my high beams just started messing up.
When I pull out the knob to cut on my fog lights, my high beams cut on as well. And at night I can see my high beam indicator barely light up. Also when I keep the fog lights off and just cut on my high beams, the lows shut off, then if I pull the fogs on, the fogs and lows cut on.
Has anyone encountered this or does anyone have any ideas to what is going on?
Thanks for any help.
Sponsored Ad
Register to remove this ad.
01RamSport318 is offline   Reply With Quote
Old 11-07-2016, 06:00 AM   #2 (permalink)
R.L.K.'s Avatar
Ram Year: 2014 4X4 QC Express 6 speed auto 355 differentials
Engine: 5.7 Hemi
Default
Well , your not doing anything wrong . You posted a Heading that briefly describes your issue and you posted in the correct area .
Welcome to the Ram Forum Sir glad to have you here !
Read lots post lots and help others when you can .
As for your issue , have you owned this truck since new ?
Have you installed an aftermarket harness for high beams with fog light operations?
If your trucks lighting system is 100% OEM then I'd be looking for a lighting module or a relay ?
Hope this helps !
R.L.K. is online now   Reply With Quote
Old 11-07-2016, 09:20 PM   #3 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
I'm putting this out there because mine did this too. Since you have aftermarket lights, im going to guess its got electronic ballasts if its got this problem. Most all Aftermarket LED or HID drivers will run full bridge rectifiers on the input to work with positive and negative ground systems.
Before you read further, the low beams are supposed to shut off when you turn on the high beams. On incandescent bulbs if it didn't, there would be increased wear on the filaments from the increased heat production of long term high beam usage.
The lows coming on with the fogs however, is not supposed to happen.
What has likely happened is one of the drivers has failed and is sourcing ground through the fog lamp relay. Do you have sport model and or DRL?
The easy fix is to go get a power resistor (preferably wire wound) and put it in parallel with the high beam plug. I cant remember the exact resistance needed, I calculated it out one time to fix this same problem on my truck, but I never got around to it.
Our trucks are positive ground on the front lighting system, everything is backwards. Only experienced techs, techs who've been trained on positive ground systems, and people who have a knack for electrical can quickly and easily solve these problems. Normal guys can as well, but it is more difficult for them.
Try this. Turn on your low beams and fogs. You high beams should also come on. Unplug one of your headlights and see if the highs turn off, if not, try the other headlight. That is the easiest way to rule out which light is malfunctioning.
Sorry if I cant be of much help, over the internet diagnostics of the front lighting system is kind of difficult.
Old 11-19-2016, 12:53 PM   #4 (permalink)
Ram Year: 2001
Engine: 5.2
Default
I have not had the truck since new. I have had it for about 5 years though. The same lights have been in the truck for about 3 years now. All the lights are OEM. They are regular bulbs that have a deep yellow tint on them which makes them yellow. They are not HID or LED. I can't look back to see if I mentioned this but at night when I cut on the fog lights and the brights cut on with them, there is about a 2 second delay before the brights cut on. And sometimes the brights won't come on at all, but when I just flash my brights, they stay on when the fogs are engaged. Either way, (only when it is dark outside) the bright light indicator comes on very slightly when the fogs are on. The indicator works normal when I am not using the fogs at all. For the past 4.5 years the lights have worked great, and the dims would stay on when I cut the brights on. And now if I have the fogs off and cut the brights on, the dims go out. It happened out of the blue, after watching a movie at the drive in theater. I looked for a ground wire but have no clue where one could be. Does anyone know if it could just be a bad ground? And if so, do you know where one might be located? Sorry this is so long, it is just a very confusing scenario to me and don't know how else to explain it.
Old 11-19-2016, 12:56 PM   #5 (permalink)
Ram Year: 2001
Engine: 5.2
Default
Yes, it is a sport model. Do not know what DRL means, sorry.
Old 11-19-2016, 01:02 PM   #6 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
Daytime Running Lights
Old 11-19-2016, 01:17 PM   #7 (permalink)
Ram Year: 2001
Engine: 5.2
Default
Oh ha, nope, but that reminded me, when I just have the running lights on and cut on the fogs, the highs still cut on as well... even with the headlight switch not turned to on.
Old 11-19-2016, 02:08 PM   #8 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Highly possible the high amperage of the factory lights (especially the sport quads) melted the inner part of the switch. Very common issue. Id start with a switch replacement and probably add a relay to take the load off
MagSport likes this.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
dapepper9 is online now   Reply With Quote
Old 11-19-2016, 02:32 PM   #9 (permalink)
Ram Year: 2001
Engine: 5.2
Default
Are you meaning the light knob or the turn signal (bright) switch?
Old 11-20-2016, 01:20 AM   #10 (permalink)
MagSport's Avatar
Ram Year: 1999
Engine: 5.9
Default
Knob
__________________
99 Ram 1500 Sport
MagSport is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2013 ram express high beam issue dhay13 General Discussions 1 07-16-2016 02:25 PM
High and low beam together just plain bill Exterior 0 11-06-2015 07:11 AM
High Beam issue...as in not working. 2012sport Exterior 2 06-19-2015 08:18 PM
HID High Beam Issue Slusho Audio & Electronics 1 06-09-2013 09:58 PM
Fog/High Beam Kit redram2007 For Sale 12 02-16-2013 01:11 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
