I have a 2000 Ram sport and the fog lights just quit working on it. The indicator next to the light switch shows that they are on but they are not. I have checked the fuse in the engine compartment and it is ok. From what I have read on the internet is the relay for the fog lamps should click when the lamps are turned on which it does. I turned them on and then pulled the relay and put it back in and the relay clicked, when the lamps are turned off it does not click. I have swapped the relay out with the horn relay and it makes no differance. The one thing that I noticed is when I pull the fuse out and put the test light leads on where the fuse plugs in the test light will not light. When I do this same test with the parking light fuse next to it the test light lights up (this was done with the lights in the on position) Could the light switch be bad?? I read somewhere on line that there have been issues inside the fuse box, could there be a issue there ??
Any help would be much appreciated as the truck just dont look right without the lamps on.
