Fuel pump wire harness
870master
5.9 v8 360
hey all,
while fixing a blown out brake line i had to drop the gas tank. I figured i would replace the fuel pump while i was there and because some connections broke in the process..... now, i am aware on the 6 pin to 4 pin electrical adapter for the fue pump, however here lies my problem.
I cut the wires to the electrical connection because i need a new connector. I can not however find a new 6 pin connection/ harness. Can i re-pin a 4 pin connector and use only the wires that are needed or is there a 6 pin harness out there that i can splice together?
dudeman2009
Magnum 360
You can use the 4 pin connector, you'll just have to splice a couple wires together.
First, the dark green/black wire from pin 1 on the six pin connector will connect to the dark green/black on pin 4 of the 4 pin connector.
Second, the black wire on pin 6 and the black/white on pin 4 of the six pin, splice together and connect to the black wire on pin 1 of the four pin connector.
Third, the black/light blue wire from pin 5 of the six pin connector connects to the black/light blue wire on pin 2 of the four pin connector.
Lastly, the dark blue/white on pin 2 and dark blue/orange on pin 3 on the six pin connector splice together and connect to the dark blue/white wire on pin 3 of the four pin connector.
870master
5.9 v8 360
Dudeman, you sir are in-fact THEE Man
Thank you sir, that is a big help.
therapywolf
