Doc_USN_retired
I am trying to find a way to wire the headlights and parking lamps onto a push button switch, fogs would be on a separate switch as well as any other lighting. my headlight switch does not work ( only the cargo light functions on the oem switch). would i need to go back to the fuse block in the engine bay to wire everything through relays to a switch? or can it be done at the oem plugs?
