installing aftermarket hu with infinity
Howells
Kitchener Ontario
5.9L
I have a clarion Hu and the Metra 70-1818 wiring harness. Didn't get any instructions with the harness does anyone know what wires go where. Thanks.
headhunter123
5.9 V8
It should show on the wires. If not, check behind the labeling.
rammy98
5.9 magnum
White - are left front
Grey - are right front
Green - are left rear
Purple - are right rear
(Black lines are negatives)
Your application has rca jacks so just plugg them in to your front and rear pre outs on the back of ur stereo. White & grey on fronts. And green & purple on rears. If ur adding sub(s) then u put that rca to ur sub output.
Red - ignition/acc 12 volts
Yellow - constant 12 volts
Black - ground
Blue- amp turn on
Orange - illumination
richclegg
HU installation
Rammy's got it right. Remember to connect or ground the parking brake wire. If you don't some of the features might not be available.
