rammanriley20
- Nov 4, 2013
- 1,502
- 790
- iowa
- 1999 Ram 1500
- 5.9 Mag
So occasionally I will have this issue, and then it will go away for a while... And come back. I recently got a pair of LED pods for fog lights, and I wired them right into the factory sport fog wiring harness so I could run them from the factory 3 way switch. And a while back I got the SBL LED headlights to go in my sport housings. Okay so for the problem. Sometimes when I go to turn my lights on I'll turn the switch to the headlights on position, and instead of the low beams coming on the high beams only will come on. Then if I pull the switch to turn the fogs on the fogs will come on along with the low beams, so all of my lights are on, and its too bright. But if I switch to the parking lights and pull for the fogs the top side of the low beam lights will come on with the fogs. And now in a couple days this problem will go away... And come back later. Anyone have any idea?
