Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Audio & Electronics
Audio & Electronics
Mirror Wiring
This is a discussion on Mirror Wiring within the Audio & Electronics forums, part of the 2nd Gen : 1994 - 2002 category!
I have a 1998 Ram 1500 with less than 98 thousand miles. I recently bought a 27 foot trailer and ...
Reply
Old 08-21-2016, 12:55 PM   #1 (permalink)
Ram Year: 1998
Engine: 5.9
Unhappy Mirror Wiring
I have a 1998 Ram 1500 with less than 98 thousand miles. I recently bought a 27 foot trailer and the stock mirrors would not allow me to see down the sides of the trailer. So I oped to replace the power and heated mirrors with a set of after market tow mirrors. the first problem i ran into was that on the drivers side, when mounting the top stud was too long and need to be shortened so that it would not hit the switch that activates the mirrors. But the big problem is that when the mirror harness was plugged into the truck harness the mirrors would not activate. the mirrors can be activated by using a small 12 volt battery but not when its plugged into the truck.
So is there a fuse or some thing hidden some where under the dash?
Sponsored Ad
Register to remove this ad.
randombb is offline   Reply With Quote
Old 08-21-2016, 01:51 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 318
Default
I'm going to guess that the switch has not been tampered with, just the wiring.
Seeing as the old mirrors worked but the new ones dont, try hooking one of the old ones back up (no need to install, just plug it in) and see if it works, you can cut almost all of the troubleshooting out if they work.
If not, and they did work before, its likely you blew a fuse, check the image for the location of the fuse for this circuit.
Old 12-01-2016, 07:53 PM   #3 (permalink)
Ram Year: 1999
Engine: 5.9l Magnum
Default
I replaced my oem mirrors as well but ended up getting the manual non heated ones as a gift. So I'm not much help on that end but I had a similar issue when putting in the 3 bolts. 2 seated fine, but the 3rd top one, was a lot longer. I ended up wrapppin it with a shop rag and tightening it in with a pair of channel locks.
Redneck760 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Center Rear View Mirror wiring access???? LOFSFIRE Interior 3 03-17-2016 10:22 PM
who has wiring diagrams for the mirror and rotary shifter?? Outdoorsman1500 Tech Info 2 04-10-2015 09:17 PM
Hooking up radar detector, need wiring from mirror Long Islander Audio & Electronics 29 07-28-2014 04:08 PM
98-01 mirror upgrade wiring info Dodge96Ram Exterior 6 03-02-2014 03:03 PM
No wiring for auto dimming mirror b_palmer22 Interior 5 11-28-2012 12:26 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
