Need help with speaker installation
MarcR
5.6l V8
So I'm trying to replace the rear speakers in my '95 B2500 van and I'm a little confused. I'm replacing the stock Infinitys with Polk DXi 691s, but I don't see an obvious way to connect the old wiring to the new speakers (pics attached). Could someone help get me started? I have access to all the tools I could need, but I haven't done anything like this before and I'm a little lost. Any advice would be much appreciated!
M
MarcR
5.6l V8
Not sure why the pictures are upside down...lemme know if you need any more info!
richterat83
V8
Have you tried removing the amp from the Infinity speaker? On mine, with the amp removed, there were 2 pins connecting the speaker to the amp. Unplug and plug into new speaker then tuck the amp away somewhere so it doesn't move.
M
MarcR
5.6l V8
Do you know which wire is positive and negative? One is white and one is blue.
