oem fog light harness
LaurenMagnum360
Illinois
360 V8
can someone who has factory fog lights on their 98-01 ram take a picture of the factory harness please? i'm trying to find the plug on my truck (think i found it) so i can get the appropriate harness so i can install my new oem fogs. :)
MoparMagic'00
Arkansas
5.2 Magnum
no way for me to take pics right now but its pretty simple.. under truck on core support about middle of it only 2 prongs and when probed both will have power..
LaurenMagnum360
LaurenMagnum360
Illinois
360 V8
So where do the foglights ground naturally if both wires are hot?
MoparMagic'00
Arkansas
5.2 Magnum
switch turns one into ground.. ****** setup but thats the way they did it i found out the hard way lol lights were touching the metal on bumper and thus created complete circuit when i added fuse had to remount them so they were not grounding then...
LaurenMagnum360
LaurenMagnum360
Illinois
360 V8
i'll have to break out my FSM and find out which one is the ground then lol. also need to buy the factory headlight switch with pull for fog option
MoparMagic'00
Arkansas
5.2 Magnum
in my 00 all i did was swap the headlight switch for the one with fogs, add the fuse and relay, turn them on and verify i had power and ground, wire it up.. then found out when the lights where grounded it stayed on and realized what was happening.. moved lights about 1/4 inch back and no problems since then.. a lot easier than trying to find it in the fsm.. my .02 though
HighTechRedneck
318 Magnum
Anyone have a picture of where the harness is inside of the dash of a 95? I can see the external harness on the bumper, but not the other end?
