Power Locks stop Working???
Jbtgame
North Branch, MN
5.9L Magnum
I have a 98 1500 and have been fixing all the rust on the truck. I bought new doors that had only a little light rust so they were easy to fix. I put the front drivers door on and tested the windows and locks. windows work, but locks do not, on either side. I have not replaced the passenger door yet. I switched the wiring harnesses, but the locks still don't work. And yes I checked the fuse. Idk what the problem could be, I had the battery unhooked and everything, so I don't think anything could have shorted out. Thanks in advance for any help.
EDIT: plugged in speaker and it also doesn't work. :( Please help!!!!!
EDIT: Also wondering what the hot wires are, I could only 1 on each plug in. I larger red wire and a white wire (I think).
