Tag light wiring help please
jonwalden68
jonwalden68
Also my truck doesn't have fog lights factory will the factory ones mount to the bumper then I'll just wire up
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
For fog lights you should have bits and pieces already there. You'd just have to go to the junkyard and pull the harness for them.
jonwalden68
jonwalden68
I ment like is there places to bolt factory style ones up even though I don't have any factory ones? I was gonna buy a harness I just didn't know if there is place to bolt up I have the holes up front for light to show but didn't know about bolting up?
Do you know a part number for wiring harness for tag lights?
jonwalden68
jonwalden68
Or how would I wire into the tail lights for the tag lights
LaurenMagnum360
Illinois
360 V8
if all else fails, just wire them up to your parking lights.
when i install the triple red clearance lights on the rear by the license plate, i always tap into the tag lights since the LED marker i use draws 1.2 amps.
fastSdime
Westmoreland, KS
1999 Ram 1500
5.9 Magnum 360
You have to have that harness going across the back from one side to the other or you wouldnt have a passenger taillight. I did mine in the dark under my truck. If my wife didnt take it I would take a better pic of everthing for you. On the foglight situation its really easy. I put some on my truck just didnt use factory wiring. So I can now run just running lights and fogs
http://www.ramforum.com/f17/fastsdimes_build_thread-38090/index2.html
