dodgeboy1
- Nov 26, 2014
- 16
- 0
- 2000
- magnum 5.9
2000 dodge ram 1500 5.9 -- died and wont start up-- .help!!
Hi there all! I Have a 2000 dodge ram 1500 5.9
The other day i was driving and the truck just completely shut off and would not start...just turned over like i was out of gas. ..code read p0351...i changed the coil, rotor and cap, plugs and wires, no change. ...so i replaced the crank sensor no change, replaced the cam sensor and it fired right up. ..drove it for 10 minutes and it died again and would not start. ..Same issue as before...the cam sensor cost me 100 and i dont want to jave to keep buying them...could it be the computer?? Please help asap this is day 3 now and dont wanna bring it to a garage if i dont have to because they are too expensive
Any other info you need let me know
Its definitely not a fuel issue ...pump comes on and the spray test works fine
Thanks all and looking forward to hearing an answer to this weird and crazy problem
