Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Tech Info
2001 ram 1500 swap in dana 70 have ?s
This is a discussion on 2001 ram 1500 swap in dana 70 have ?s within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
like it says above 2001 ram 1500 want to swap a dana 70 into it. I know about the spring ...
Reply
Old 11-18-2016, 10:34 PM   #1 (permalink)
Ram Year: 2001
Engine: 5.9
Default 2001 ram 1500 swap in dana 70 have ?s
like it says above 2001 ram 1500 want to swap a dana 70 into it. I know about the spring perches and drive shaft but it has disc brakes and I have drum brakes. how does that hook up work?
Sponsored Ad
Register to remove this ad.
workinguy26 is offline   Reply With Quote
Old 11-19-2016, 08:32 AM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Should be able to connect brake lines and bleed em like you would the fronts
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 11-19-2016, 08:11 PM   #3 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Agreed.
But Pepper, I had a 79 Ramcharger and I put a GM 14 bolt in it with a disc brake conversion and I had no brakes as the calipers take way more fluid to move than the stock master could move. Forcing me to put on a different master, I used one I had off a Chevy dually cube van. After that swap I could lock all four 36x12.5 Super Swampers up on the highway easy. But I couldn't hardly stop with the stock master.
That being said, as I may eventually swap to rear disc 70 also, how does the stock master work with the Dana 60 disc front / Dana 70 disc rear?
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 11-21-2016, 05:09 PM   #4 (permalink)
DodgeTx's Avatar
Ram Year: 2000
Engine: 5.9L
Send a message via Skype™ to DodgeTx
Default
I have wanted to make this swap. I did not know of the differences or how easy it would be. (potentially depending on mindset)
DodgeTx is offline   Reply With Quote
Old 11-21-2016, 09:46 PM   #5 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
It's an easy swap but we have to figure out if the stock master will work. Swapping a master is easy also but it would be nice to know before I drive down the road to test it. Or swap masters for no reason.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 11-21-2016, 10:28 PM   #6 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Others have done the swap before and there's conversion kits out there for the 9.25 that don't include a new master. These masters are a bit stronger than that 79 ramcharger so i wouldn't worry about it. In fact i bet if you cross referenced part numbers they'd probably be the same as the 2500/3500 trucks and if not those would be almost guaranteed to be a direct swap
__________________
Old 11-21-2016, 10:52 PM   #7 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Ya, my 79 had no braking issues with rear drum Dana 60 brakes. Just a big issue with calipers.
Mind you, my disc conversion on the 14 bolt used 8 lug 10 bolt front rotors and calipers.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dana 60 swap help dodgeramforlife General Discussion 2 11-22-2016 07:37 PM
2001 Ram 1500 Manual Transmission Swap/Conversion LackingCreativity Engine & Performance 7 11-03-2016 06:46 PM
1999 dana 70 put in 2002 ram 1500 AustinAH 3rd Gen DIY 7 10-12-2016 08:06 PM
Chrysler 9.25 Rebuild or Dana 70 Swap?? thatblue2ndgen General Discussion 12 03-13-2016 01:45 PM
Stock Dana 44 and Dana 60 upgrades? Dcolts2000 General Discussion 5 07-03-2014 12:14 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
