Hi all,
Good to be here, looks like a pretty active site with lots of good info. For some reason the search function is inop, probably due to the work computer.
Anyway, I'm looking for some information regarding 46re and shift kits. Going to be rebuilding the trans within the next few weeks and have purchased the sonnax sure cure kit. I'm also wanting to couple this kit with a shift kit to firm up the 1-2 and 2-3 shift. The sonnax kit addresses everything except the first two shifts. One person on another forum suggested using the transgo jr kit as a guide to drill the plate, but to follow the sonnax directions for everything else, seems like a good approach? Has anyone drilled the separator plate along with installing the sure cure kit?
Thanks!
Thanks!
