Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Tech Info
95 46RH wiring hacked...
This is a discussion on 95 46RH wiring hacked... within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
Well, i just bought a 95 RCSB 2wd 318 auto. I drove it 5 minutes to my house and noticed ...
Reply
Old 11-01-2016, 11:55 PM   #1 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default 95 46RE wiring hacked...
Well, i just bought a 95 RCSB 2wd 318 auto. I drove it 5 minutes to my house and noticed that it was hesitating really bad while trying to go from a stop. I thought it was a fuel issue, but today, i was backing up, and noticed that it doesnt bog at all. I could do a burnout in reverse if i wanted to...
so i remember from my previous job about transmissions, and i have figured out that my truck, when in drive, is starting off in 3rd gear. I key on/off/on/off etc to get codes, and i have the following:
37: trans converter solenoid (this code flashed twice in a row...)
45: trans overdrive
32: egr
So i got under it and noticed that 3 wires out of my 8 wire harness are cut and folded back on themselves...
The 3 wires that arent connected are:
Violet/wht: governor pressure solenoid control
Orange: 5v supply
Red: transmission control relay output
So, i tried digging through my conduit to see where these wires were cut back to, and... they arent... those 3 wires just arent there... i traced the conduit up to the T under the wiper cowl, and there are no cut wires... i have no freaking idea where to go from here...
Im also missing a pigtail that plugs into a 2 pin sensor or something on the bottom drivers side of the transmission between the pan and the trans mount...
I will get some pictures here in a sec. I really need some help, so thank you in advance!
Sponsored Ad
Register to remove this ad.
analog56x is offline   Reply With Quote
Old 11-02-2016, 12:06 AM   #2 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
Here are those pictures
Old 11-02-2016, 02:29 AM   #3 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
Upon giving myself a headache with reading, i think i figured out my problem... someone stuffed the wrong trans in this truck before i bought it... ive got the 95 ecm with the 60 pin connector, and at least 2 of the wires from my transmission are located in the second of 3 plugs on the 96 ecm... i dont suppose there is any way to make this work... it makes sense that the harness is missing those 3 wires now... they dont exist in my 95 haha... damn... now what to do...
Old 11-05-2016, 11:00 PM   #4 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
My best guess is that your truck was originally equipped with a 46rh (hydraulically-controlled governor) whereas now it has a 46re (electronically-controlled governor) and your OBD1 ECU either isn't configured to operate a 46re (hence the chopped off wires) or, assuming the RE was used with OBD1 computers, said transmission has a different wiring harness for an OBD1 ECU vs an OBD2 ECU, but whoever swapped the transmission in decided to hack up the wiring rather than do a proper harness swap.
Assuming the former, you might not have a choice but to swap the transmission. Assuming the latter, a new wiring harness might be your ticket.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
American Racing Nitro, K&N open element, modified 50mm, 2.25" y-pipe, Magnaflow 99069HM, Cherry Bomb Extreme, tuned by Flyin' Ryan, steering stabilizer, 4x4 Posi-Lok, Cobra fuzz-buster
Yeret is offline   Reply With Quote
Old 11-06-2016, 10:35 AM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Yeah some asshole swapped in a 46re. 46rh will work in place of a 46re but not vice versa without also changing the harness and pcm.
Reason is the RE has more computer input for how it behaves and pcm is looking for specific readings. If it gets anything outside of these readings or nothing at all it'll start the vehicle in a high gear. This is done to allow it to be driven on the highway in case of emergency
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Reply
Bookmarks
Tags
1995, 318, 46re, ram 1500 2wd, transmission
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
46rh issues MANKYPURPLE Engine & Performance 0 06-14-2016 02:01 PM
46RH issues MANKYPURPLE Engine & Performance 0 06-13-2016 02:45 PM
Uconnect hacked and controlled remotely! Chrysler RECALL ! R.L.K. Audio & Electronics 4 07-24-2015 05:18 PM
UConnect has been Hacked!! NorthTexasHemi Audio & Electronics 33 07-23-2015 10:35 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
