Hey there, I was wanting to know if anyone can answer my question of why my cruise and odometer don't work. I just did a tranny swap from 47re auto to nv4500 manual as well as transfer case swap. The new case came out of a 98 and has no place for the speedometer sensor to plug in. I guess in 98 they began reading the speed off the differential. I ended up buying a dakota digital sgi 5 and pulled the signal off my rear abs. I spliced into the red wire coming from the sensor in the differential and then put the 1 of 3 white wire from my transfer case speed sensor into the output location on the sgi 5. The black from the speed sensor is to the ground and the orange is taped off...not hooked up. I am getting the speedometer to work and the trip odometer works but not the cruise. The main odometer flips one tenth every mile I go.
Does anyone know why both odometer's don't work together and why my cruise doesn't work? If my signal is pulled off the abs and then recalibrated with the sgi 5 and output into the regular speed sensor wire, why wouldn't everything work as if it was plugged into the original sensor in the transfer case?
Do I have the SGI-5 hooked up wrong or on the wrong setting? Does the orange power wire need to complete the circuit? I thought that if the speedometer was working that the odometer would too...does the main odometer read off the computer? Is the imput signal to weak since I spliced into abs sensor?
Can anyone help? It's over my head.
