jpm8463
hello all. new to the forum but have used it a ton for this new ram i bought and the info and support from your site convinced me to join and post. hopefully as i work on this ram i can help others with what i learn and draw from the vast knowledge that all of you other members provide on that note...
i have a 99 1500 with the 5.9l and in the process of replacing the passenger side front axle seal/ wheel bearing/ axle shaft u joint i discovered that i am missing a seal/dust guard that rides right next to the u joint assembly between the u joint and front axle tube. this seal/guard is for keeping debree out of the passenger side axle tube. my question is if anyone knows the part number for a aftermarket replacement or even dealer#. went to my local dealer here in waterford, mich and even they did not know what i was looking for. here is a pic of it on the drivers side.
thanks in advance for the help.
