I bought this truck third-hand not too long ago. Since I've had it, the cluster has been lit up with an ABS and Brake warning light. I was assured by the previous owner that the brakes were in good shape, which they are. I can tell new lines and new master cylinder were installed, however, the ABS does not work and I'm playing around with what could be the issue. I'm suspecting it's the ABS reluctor ring in the rear axle, if it uses one (similar to GM RWD vehicles). I don't really want to go around the truck replacing $150 wheel speed sensors if I don't have to, since of course I don't have a Chrysler tech tool to tell which one it is. Anything I should check before I start replacing wheel bearings/sensors?
