AC does not blow from dash vents
JohnRBurke2
Detroit, mi.
5.2 V8 Magnum
I recently bought a 2001 Ram 1500 and the AC works but does not blow out of the front dash vents (it works fine for the floor vents and defrost vents)
I assume this is an easy fix of a hose or something, any advise would help.
JohnRBurke2
JohnRBurke2
Detroit, mi.
5.2 V8 Magnum
Thank you dodge dude. It is my understanding that "wild vents" switches to defrost while accelerating; this is not my problem. My AC will not switch to the dash vents at any time. While driving or not.
Is this caused by the same problem?
JohnRBurke2
JohnRBurke2
Detroit, mi.
5.2 V8 Magnum
I was told that I need to replace the blend door motor on the passenger side, underneth the glove compartment to fix this. Any thoughts and advice on where t get a new blend door mktor?
MoparMagic'00
Arkansas
5.2 Magnum
that blend door is for temp selecting... does it change to anything else at anytime?
am3334
