Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Tech Info
Brake issues
This is a discussion on Brake issues within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
1997 1500, 5.9 I am having issues with a soft brake pedal. When I hit the brake pedal, I hear ...
Reply
Old 01-01-2017, 05:51 PM   #1 (permalink)
Ram Year: 1997
Engine: 5.9 Magnum
Default Brake issues
1997 1500, 5.9
I am having issues with a soft brake pedal. When I hit the brake pedal, I hear what sounds like a rush of air from the pedal area and I have little to no pedal resistance for what I would guess is about 75% of the pedal travel. Everything in my mind is telling me they need to be bled, but I have bled them multiple times and and I am not getting air out of the system any more. If I disconnect the hose off the booster, the pedal is hard. If the engine is not running, the pedal is hard.
I have replaced:
- Rear shoes and wheel cylinders.
- Adjusted rear brakes
- Front rotors and pads
- both front soft lines
- master cylinder
At times, not every time, the pedal, within the first 25-50% of travel, feels like it is catching on something, but i am not seeing anything around the pedal area that would be causing that. Maybe something with the rod between the booster and pedal? Either way, that shouldn't be causing my soft pedal.
The only thing I havent replaced is the booster itself, but as far as I know, a bad booster would only cause a hard pedal, not a soft pedal.
Any thoughts?
Sponsored Ad
Register to remove this ad.
jesterx888 is offline   Reply With Quote
Old 01-01-2017, 06:25 PM   #2 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
Check for leaks in the brake lines, same thing happened to me and it was leaking wheel cylinders
12vcummins59 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
more brake issues 12vcummins59 General Discussion 17 12-06-2016 06:47 PM
Brake issues R/T_Fire Exterior 2 06-15-2015 12:51 PM
Brake issues Shane_o_ca General Discussion 2 09-08-2013 08:18 PM
Brake issues... shibby927 General Discussions 17 06-08-2012 08:02 AM
brake bleeding issues! need help 04hemi2500 General Discussions 27 04-23-2012 06:49 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
