cam or gears?
94ram1500
jay oklahoma
Hello everyone, question... I have a 94 1500 5.9, bone stock pu, I'm going to be buying and towing a two horse trailer, I haven't bought the trailer yet but I'm guessing between my horses, which average about 1200 a piece, and the trailer itself, the whole tow load will be 5,500-6,000 lbs, What would be the best route for extra power, a cam replacement, or steeper gears , go from 355 to 390's? also will the stock computer be compatible with a new torque profile camshaft?
Thanks
dudeman2009
Magnum 360
Cams really only give a small increase in power on a stock setup. You would be much better off spending the money that you would otherwise put into gears or a cam + equipment to do so, on a tune. That is by far the easiest and most effective way to increase power per dollar.
mda8569
Vandalia Ohio
5.9 magnum
If he didnt have an obd1, he could tune for it. Gears, definitely.
dudeman2009
Magnum 360
I didnt see the year.
