Sorry I meant the code reader will not link to my truck. 99 ram sport 5.2 4x4. So went to local auto parts store to see what codes I had. My gauges worked I can pull up the codes on the odometer but not with a code reader. Just wouldn't read through a code scanner. I do have an issue that sometimes my cluster will get loose and I have a air bag light come on. Push in on the dash and it goes away. (This is a different issue but wanted to give all info I can. The stock radio harness was cut out also. I have a aftermarket radio in in now. I think something is messed up with the amp or speaker. Right the side sounds good. Left side bass is not there. Switch leads from left and right it does not change. Had two different head units in there.) the truck starts and runs good. Except believe my plenum gasket is bad. Gauges work. I plan on getting a tuner after engine swap, axle swap but wont this effect trying to tune it. Thanks In Advance for help.
