Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Tech Info
Fuel Problem, not the fuel pump
This is a discussion on Fuel Problem, not the fuel pump within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
So I'm driving down the road and I lose power.. can rev the motor but its not going any faster, ...
Like Tree1Likes
Reply
Old 02-07-2015, 02:08 PM   #1 (permalink)
Ram Year: 2001
Engine: 5.9L magnum
Default Fuel Problem, not the fuel pump
So I'm driving down the road and I lose power.. can rev the motor but its not going any faster, just coasting to a stop.. I thought it was the transmission by the way it was acting. When I get to a stop, the truck dies, so I try to start it back up and it feels like its misfiring on all cylinders, runs for a few seconds, then dies again, but starts up every time.
Get it towed home and change the IAC valve, detail the throttle body, nothing helps. So I figured it might be the fuel pump even though its getting gas at the rails and I can hear the pump kick on. Do a test and its shakey at about 45-48psi.. but then sometimes while its started and shaking violently, something will catch and it will run perfect, but rev to like 4k, then slowly go back down and die. Well it did this while the pressure tester was hooked up, and while it was running perfectly the psi jumped to a steady 50. Fuel pump! I thought, so I had one overnighted to me.. changed it out today, started her up, and exact same thing is happening.. Anyone have any ideas? Also like to add I'm only getting one code and its gas cap leak... might be important now that I think about it
2001 Dodge Ram 1500
5.9L v8
Sponsored Ad
Register to remove this ad.
pwebyd90 is offline   Reply With Quote
Old 02-07-2015, 05:27 PM   #2 (permalink)
MagSport's Avatar
Ram Year: 1999
Engine: 5.9
Default
I had this issue shortly after I did my heater core. Cleaned my battery terminals and tightened everything down tight and it fixed it. Don't know if it would be the same for you, but if these trucks have a bad connection at the battery, the Ecms go all crazy
MoparMagic'00 likes this.
__________________
99 Ram 1500 Sport
MagSport is offline   Reply With Quote
Old 02-07-2015, 06:11 PM   #3 (permalink)
crazy_luck's Avatar
Ram Year: 2013
Engine: 5.7
Default
Some of this sounds like symptoms of a plugged/bad catalytic converter...
__________________
2013 Ram 1500 Express - Snow&Go
2006 Charger Daytona - Show&Go
crazy_luck is offline   Reply With Quote
Old 02-09-2015, 10:42 PM   #4 (permalink)
Ram Year: 2001
Engine: 5.9L magnum
Default
If it were the cat would it throw any codes? And I'll check the battery when I get home, I'm out of town for a couple more days.. Thank you for the replies
Old 02-09-2015, 10:54 PM   #5 (permalink)
Ram Year: 2001
Engine: 5.9L magnum
Default
Were you having these exact problems? If it turns out to be just the battery I would be sooo happy
Old 02-10-2015, 10:08 PM   #6 (permalink)
MagSport's Avatar
Ram Year: 1999
Engine: 5.9
Default
I didn't check the fuel pressure at the rails but the truck would not idle without throttle and it would still have erratic revs. I looked over everything I had messed with while messing with the dash and my terminals were pretty corroded. Cleaned em up, replaced terminals and added the foam pads, and that solved the problem, truck ran flawlessly. I would check this before anything else since this would be a relatively cheap repair if it's the problem. Report back with findings! lol
__________________
99 Ram 1500 Sport
Old 02-13-2015, 07:30 PM   #7 (permalink)
Ram Year: 2001
Engine: 5.9L magnum
Default
Cleaned the battery up nice and shiny, didnt change anything.. multimeter had good readings. Its been too long and too stressful, so I finally had it towed to my mechanic. Hopefully we'll know whats going on tomorrow
Old 02-14-2015, 01:22 PM   #8 (permalink)
MagSport's Avatar
Ram Year: 1999
Engine: 5.9
Default
Have you found out anything?
__________________
99 Ram 1500 Sport
Old 02-14-2015, 01:38 PM   #9 (permalink)
Ram Year: 2001
Engine: 5.9L magnum
Default
My mechanic said the previous owners must have cut my CEL, so thats great =/
Only thing he can guess is bad ECM.. sound plausible at all?
He said when he hooks it up to his scanner its not showing the computer at all, and he tried unhooking sensors to try and get it to throw codes and its not doing anything.. someone suggested crankshaft position sensor, but he said since it starts its not lack of spark or anything of that nature.. cheapest computer I can find is $217
Old 02-14-2015, 02:19 PM   #10 (permalink)
Ram Year: 2001
Engine: 5.9L magnum
Default
Which fuse is responsible for powering the OBDii port? That may be the problem, but cant find which fuse it is through googling =/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
05 5.7 Hemi Fuel Pump/Gauge Problem WGSNewnan Tech Info 5 01-21-2016 10:57 AM
fuel pump? Bolt Engine & Performance 2 07-19-2014 01:58 PM
Fuel pump johndeeregreenmachine Engine & Performance 2 12-24-2013 12:44 AM
Fuel Pump? ramman54 Engine & Performance 2 09-10-2013 11:41 PM
put new fuel pump on still does it jcp dodge Engine & Performance 3 02-20-2013 05:03 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
