fuel sync instructions
luvmyramm42
Magnum 4.2
I was pulling a heavy load in my 98 ram. has 4.2 l magnum engine have since replaced timing chain and gears did all new gaskets and everything but cant get the fuel sync correct seriously need to get this done and cant find any usefull information....HELP PLEASE
L
luvmyramm42
Magnum 4.2
DRB3 fuel sync
ok so I am about to rent a drb3 emulator tool to finish my truck. First question is what are the steps I need to take while doing this so I can get my truck on the road again.. should I start completely over under the timing cover to get everything lined up correctly. also what else should I do while I have this $2500 tool at my disposal. Lastly anybody in the Centre, Alabama area that would like to use the tool for a small fee let me know...
Merc225hp
NA
truck
gas
The steps on how to set the Fuel sync can be found in the Factory service manual, that pdf can be downloaded from RF free.
L
luvmyramm42
Magnum 4.2
ive followed every available instructions on how to do this and according to those I should atleast be able to get the truck started without the tool and I can not so im stumped and pissed I really need some help can I test the cam shaft sensor and crank sensor to see if either are bad
L
luvmyramm42
Magnum 4.2
instruction verification
http://bionicdodge.com/Download/Speedtweaks Tips And Tricks.pdf
OK according to this I can index the distributor without the drb3 using a multimeter it also says that I must rotate the timing 17.5 degrees past tdc in order to index it so really the crank and cam will be lined up but the distributor will not be put on the piston one firing spot in that position I have to rotate past that point 17.5 degrees then find the position where the multimeter changes outputs... is this correct?
L
luvmyramm42
Magnum 4.2
Anybody
Sent from my VS980 4G using Tapatalk
