Funky Sound
94Nightmare
94Nightmare
Iowa
magnum 5.9
Sorry!! Thought I changed it when I uploaded it, whoops
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Definitely sounds like a bearing trying to go out. Take the belt off and start spinning stuff.
bob.finn.75
My first guess would be water pump or fan clutch.
homeguy
Calgary AB
2013 Big Horn
I'd say pulley
MagSport
South Carolina
My water pump made that noise but only after the bearings inside it exploded. I would follow up on DD94s suggestion before any bearings seriously do blow.
94Nightmare
94Nightmare
Iowa
magnum 5.9
Should I be happy or concerned if the sound went away....
94Nightmare
94Nightmare
Iowa
magnum 5.9
Alright, got the belt off and its definitely the tensioner pulley. Should I just replace the pulley, or the whole tensioner?
Merc225hp
NA
truck
gas
If the tensioner is moving as it should then just replace the pulley and save some $$$. You can also just change out the bearing or if you are really stuck you can grease/lube that sealed bearing by carefully removing the dust cover, lube it reinstall the dust cover.
94Nightmare
94Nightmare
Iowa
magnum 5.9
I think I'm just gonna change the pulley, tensioner seems to be moving fine and the belt isn't loose at all. Thanks!
Bobram1500
